Tractor Talk Discussion Forum
hydralic priority?
Brian 1
08-01-2005 20:55:30
Tried this on the Case board but no answers...
Can someone tell me the priority or ranking for steering, loader, transmission, and brakes when they are served by the same fluid. CIH 885 brakes went out or got very soft, didn't think at the time to check fluid as I was leaving in a hurry. Worked fine and this just started after I started using a new cylinder and hoses. Could that reduce the fluid level enough to cause that? Thanks
jake3x
08-02-2005 08:53:40
 Re: hydralic priority? in reply to Brian 1, 08-01-2005 20:55:30
A priority valve takes the pump flow and divides it into a constant 3-10 gpm for steering and the remainder to the loader valves. Steering is the main use for this valve as the rotary control depending on size must be constantly supplied with proper volume of oil. Check the valves on the www.surpluscenter.com
