Tractor Talk Discussion Forum
positive ground to neg?
Brett in KS
07-31-2005 09:59:43
I just bought a 55 john deere combine. It isn't charging, and I want to put an alternator on. I just put an alternator on our AC D-19, so I know how to do it, but it was negative ground. My question is- when switching from positive ground to negative ground, besides switching around the terminals on the battery, what else do I need to do? Thanks in advance.
Brett
Brett in KS
07-31-2005 14:54:44
 Re: positive ground to neg? in reply to Brett in KS, 07-31-2005 09:59:43
Thanks guys. Now I've got to to wait till it gets cooler out tonight. that tin can get hot! ouch!
Roger in Iowa
07-31-2005 14:16:29
Do you need another 55 for parts? I have one in north central Kansas. Grain tank bottom is rusted out.
Roger in Iowa
RustyFarmall
07-31-2005 12:02:36
Here is a link to some wiring diagrams that have been very helpful to those who work on the red tractors. The alternator conversion diagrams would apply to just about anything.
Tx Jim
07-31-2005 11:31:55
Brett if it is a gas engine you need to reverse small wires on ignition coil. Tx Jim
Don-Wi
07-31-2005 11:14:18
You would also need to switch the terminals on the guages I think, and atleast have to re-polarize the regulator if not replace it, unless you're going w/ an internal regulator model.
Donovan from Wisconsin
Brett in KS
07-31-2005 14:59:24
 Re: positive ground to neg? in reply to Don-Wi, 07-31-2005 11:14:18
Thanks Don, I forgot all about the terminals on the gauge, I'd a wondered what was wrong when I got everything hooked up and the gage showed a discharge! Also the alternator has an internal regulator so I don't think you have to polarize it.
RAW in IA
07-31-2005 12:27:45
If installing an alternator he will use a different regulator. Besides, witha generator it isn't the regulator you are polarizing, it is the generator. The regulator is designed to work with either pos or neg ground but cannot be changed as far as I know.
