Tractor Talk Discussion Forum
O.T. Lincoln Continental?????
SJ
07-25-2005 18:04:35
My son just bought a 71 Lincoln MKIII.has a 460ci that he wants to restore(please dont ask me why.LOL.)He asked if he needed to run leaded gas I told him ya cant get it,but ya can get lead additive.Told him to try unleaded and see if it pings.Now my question is,should he run hi-octane or start with a small amount of low octane and see how it runs,also where does the octane rating come in whether he uses an lead additive or not?
Thanks
Stan
JoeK
07-25-2005 18:40:19
 Re: O.T. Lincoln Continental????? in reply to SJ, 07-25-2005 18:04:35
71 was pre unleaded,however some mfgs were already preparing for the unleaded fuel by lowering compression,changing tuning and installing hardened valves/seats,Unsure of just when Ford began.He needs to check the specs on his particular engine to determine compression ratio.General rule of thumb used to be that a carburated engine below 8.5:1 would handle unleaded fuel though premium fuel/timing adj may be required to minimize pinging.If going"in depth" on his restoration such as rebuilding the engine,hardened valves/seat could be installed or possibly newer cylinder heads as the 460 was around for many years.Also the additives available are not tetraethyl lead but a mix of other chemicals to modify the fuel detonation and slow valve damage(with questionable results) and the"better" ones will add 15-20$ to the cost of a tank of fuel.Wouldn't take many fillups to pay for a valve job to run UL safely.
Easy
07-25-2005 20:42:58
 Re: O.T. Lincoln Continental????? in reply to JoeK, 07-25-2005 18:40:19
Most of the big premium cars of that period required premium gas, to avoid the knocking. That generation engine was a pain to work on. Kind of post 60's performance and before the electronic control systems got good. Make a good pimpmobile tho :))).
