Tractor Talk Discussion Forum
hey old turpentine?
HH in AR
07-25-2005 17:21:32
You replied to me about the 530 that i have stuck. I tried the trans. fluid she is still stuck. Havent been able to find turpentine. where do you get yours?
thanks Harold
Mike M
07-26-2005 05:08:09
 Re: hey old turpentine? in reply to HH in AR, 07-25-2005 17:21:32
Did you pull the valve cover and check for stuck valves yet ? These will bend a push rod or break something if you do get it free.
HH in AR
07-26-2005 06:57:30
 Re: hey old turpentine? in reply to Mike M, 07-26-2005 05:08:09
hey mike I haven't checked the valves yet. Both pistons are down somewhat from the top so I haven't worried about them yet.
Last night I used about a 6' pipe chained to the flywheel. I didn't jump on it but i did bounce it a little with my hands, I don't really know how rough I can get with it with out bending something. Before I quit last night I used a chain and boomer like you were talking about with the comealong. let it soak a while longer can't hurt, but i'll probably end up tearing it down.
Garry in OK
07-25-2005 20:58:01
Ace Hardware should stock it or can order it.
Garry
HH in AR
07-25-2005 19:29:27
The tractor has been in the shed all it's life. The paint is still fair, over all it is in good shape besides the little problem of the motor being stuck.
I messed with it for a while this afternoon never got it to move with a pry bar on the flywheel. Am guessing i'll have to tear it down before it is over. But i'll let it soak till it cools off a little, me and 100 degrees dont get along too well.
Mike M
07-26-2005 04:52:45
 Re: hey old turpentine? in reply to HH in AR, 07-25-2005 19:29:27
Since it's been in the shed things are looking good for it to run again. I just got done freeing up a B. I tried chaining a bar to the flywheel couldn't get it in the right spot to pull or jump on it was straight up in the air. I then thought of a much better/safer way looped the chain through the flywheel hole on top,hooked the come along to it then ran the cable around and over the front of the fylwheel then hooked other end to drawbar frame then tightened it up which rolled the fylwheel forward and it moved very easy.Then worked it back and forth by hand until it would go all the way around.Be careful prying in those slots as sometimes you can break off an ear. TRY THE COME ALONG and report back.
old
07-25-2005 19:34:59
Is that hand start only or does it have a starter?? If it has a starter use it, it will do more then you can do with a bar. On my 1935 B which had been stuck for 10 plus years I ended up makeing a wench for the flywheel that was about 10 foot long and it fit in to the flywheel. but 10 foot does put a lot of push on every thing
Daniel Ray
07-25-2005 20:05:04
 Re: hey old turpentine? in reply to old, 07-25-2005 19:34:59
Here's one fella's. Make a fitting that goes in your spark plug hole and rig it up to the SCV on your tractor. Take the other plug out and put a long slinder pod like an CB antiana so when that piston comes up you will know. Go easy at first, no luck, rev her up and give it to her. That is if its gas or LP.
old
07-25-2005 18:15:46
Turpentine can be hard to find now days. It took me going to about 10 places to find any and when I did I got all they had and was told that was the last they would ever have. I have since found a place to get it again but its 30 miles from me. Its a farm and home supply place.
Mike M
07-25-2005 18:12:23
Was this tractor sitting outside and for how long ?? Have you pulled off the valve cover and checked for stuck valves yet ??
Nothing wrong with trying to free it up first. If you do get it free it will make a tear down much easier if needed. I have freed up several and got them running with good results,but these were usually sitting inside or not very long outside.
37 chief
07-25-2005 17:26:51
Pull the head, and do it right. Stan
old
07-25-2005 18:19:03
 Re: hey old turpentine? in reply to 37 chief, 07-25-2005 17:26:51
Well doing it right in one person book is differant then in another persons book. I have 3 or 4 tractors that I have never pulled any more then the valve cover, and they where stuck. All of them run good and use little to no oil other then my 1935 JD-B and it does use a little oil but it also has the same rings in it that where in it when my grandfather was useing it on the farm in the 40s. So some times you don't need to pull the head etc.
