Tractor Talk Discussion Forum
f-350
chris sweetland
07-24-2005 20:32:18
we have an 88 ford f-350 diesel i hate the truck like none other the thing just wont start with out a tough of either its a dump if that makes any diffrence once it starts it runs good uausally anyone got any ideas to make er start better/eaiser?
frankiee
07-25-2005 05:58:29
 Re: f-350 in reply to chris sweetland, 07-24-2005 20:32:18
Look for a sign of wettness around where the accelerator cable is connected to the injection pump. Look hard at the side where the return spring is. Right after you shut it off and it is still hot, then look around that area and move the accelerator linkage back and forth and wiggle it, trying to get it to leak.
If fuel can come out of the bushings there then air can get in.
Mike M
07-25-2005 05:22:10
Don't use ether in them unless you disable the glow plug system. If you haven't damaged anything yet your glow plugs probabaly aren't working that's why it won't start.
Roy Suomi
07-24-2005 20:55:04
Pull wires off glow plugs and check for a light with test light with key on. Next check for continuity with test light. Put clip on glow plug terminal then put point into wire end. Keep in mind there is a timer in the glow circuit, so you will have to turn key on and off several times to do these tests.If there is no power at wire ends at all, check timer for open condition.. For cripes sake don't use starting fluid.....
Bryan in Iowa
07-25-2005 06:34:51
 Re: f-350 in reply to Roy Suomi, 07-24-2005 20:55:04
Ether is pretty hard on smaler engines .I have older GM 6.2 that gives me fits once in awhile when cold .I use WD 40 instead of ether ,,less volitol and lil bit of lubrication to it .Not near the knocking and banging from ether. But ,,,if glow plug system is working right , they should start pretty good !!!!
Redmud
07-25-2005 02:45:55
Unplug all glo plugs, attach test light clip to glo plug terminal end, touch point of test lite to postive post of battery, no light, bad glo plug. no need to turn ign. on and off.
BillD1
07-25-2005 05:29:35
 Re: f-350 in reply to Redmud, 07-25-2005 02:45:55
My 89 250 with the 7.3 would eat glow plugs the only plugs that would hold up were the Ford O.E. plugs NAPA or any of the others would not do the job
Redmud
07-25-2005 07:55:33
 Re: f-350 in reply to BillD1, 07-25-2005 05:29:35
Bill, I have a 93 F350 with the 7.3, I have never had any problems so far with starting or with the glo plugs. The plugs have been changed a few times, because I thought they needed to be changed, the controler came on the truck. I also keep good hot batteries and an up to snuff starter on it. Old weak batteries and a weak starter will cause problems that don't end after their replacement. And you are right, always get the good stuff..
chris sweetland
07-25-2005 10:15:25
 Re: f-350 in reply to Redmud, 07-25-2005 07:55:33
when i say we i mean the farm truck i personally dont use either in it i just crank the hell out of it till it starts the startes got a lifetime warranty from the shop
Redmud
07-25-2005 12:12:42
 Re: f-350 in reply to chris sweetland, 07-25-2005 10:15:25
Chris, your last post helps more than you think, If you can just keep spinning the engine untill it starts, then the engine is not in bad shape. Sounds like you are losing the prime in the injector pump. Look at the fuel pump on the right front of the engine, if its wet, this may be your problem. When the fuel pump leaks fuel, it will drain the injector pump. and you still need to check the glo plugs.
