Tractor Talk Discussion Forum
travel speed
baler 46
07-23-2005 22:25:20
Just want to know what the travel speed would be on farmall h with rear back tires? One little broblem is on one side there is a 11-38 tire and the other side is 12-38 tire size. That is in second gear and thrid grear too.thanks
Don L C
07-24-2005 16:50:49
 Re: travel speed in reply to baler 46, 07-23-2005 22:25:20
First , tire size...11" and 12" designate the tire width....that would not hurt to run them ....
What you don't want to do is run differnt dia.,rims and tires, like, 38" and 36"...the rear end gears would be compensating for the differance.
Now the tranny problem....remove the shift lever....with a long heavy screwdriver put the tranny in neutral...look at the end of the shifter....you can see where it is whore....build it back by welding and shape it back with a grinder.....put it back togeather....
Your done and saved a bunch of money.....Don-ohio
paul
07-23-2005 23:01:20
I'm a little confused what 'with rear back tires' means???? What do you mean by that?
Most H's have a way-too-fast high gear, and 4th & 3rd are a little slow. Used to be someone sold a gearset that changed 4th & 5th a bit to make them closer.
Mis-matched rear tires can be a little hard on your differential, tho at tractor speeds perhaps no big deal, I donno.
--->Paul
