Tractor Talk Discussion Forum
530 stuck
HH in AR
07-17-2005 16:43:30
You guys helped me earlier on my hay press so I come again.
I have a 530 JD that my dad bought when I was just a pup. When dad passed about 5 years ago my brother wanted the 530. Its been setting since then now the engine is stuck. I pulled the plugs about two weeks ago and squirted them full of PB blaster. Yesterday had my wife pull me home on it popped the clutch several times but all i could get was sliding the tires. Any other ideas to get her broke loose?
thanks Harold
Mike M
07-17-2005 19:25:43
 Re: 530 stuck in reply to HH in AR, 07-17-2005 16:43:30
Pulling them around is not a good idea. For one thing you can't get good traction,you are overstressing the gears and can break them and if it does move if you have a stuck valve you will bend a pushrod. I just freed up a B by pulling off the valve cover,removeing the rocker arms and push rods.See if you can push in any of the valves.I had one that wouldn't budge.I removed the carb.and exhaust pipe and filled the intake and exhaust ports as full as I could get them.I used diesel use your favorite mixture.I worked the valves I could move to let more into the cylinders.Let sit one week. Then I looped a chain through the flywheel hooked a comealong onto this chain then ran the cable over and around the flywheel. Mine was hooked on the top and I ran it around until it came down to the bottom then out towards the back I hooked the other end into the drawbar frame and then tightened up the comealong this freed up the engine very easily. I just then worked it back and forth until it would spin completely around.Then I took a hammer and a block of wood and beat the valve down,then I could roll the flywheel around by hand and the piston would tap it back up.Soaked it good with PB blaster and keep working it until freed up.Put it all back together and then towed around in high gear with the plugs out to blow out the junk and extra fluids. Then fired it up.
old
07-17-2005 17:57:58
Refill the cylinders with tranny fluid and let it sit a week or so and then try to pull it again. If that doesn't work then refill with turpentine, and give that a week
HH in AR
07-17-2005 18:07:21
 Re: 530 stuck in reply to old, 07-17-2005 17:57:58
Seems like I've heard about the trans fluid before but the turpentine is a new one on me.
I'll give that a try see How that works.
Thanks Harold
old
07-17-2005 18:12:41
 Re: 530 stuck in reply to HH in AR, 07-17-2005 18:07:21
I never found an engine yet that the 2 things I say to do don't work on. But theres probably one out there that it will not work on.
RustyFarmall
07-18-2005 07:48:02
 Re: 530 stuck in reply to old, 07-17-2005 18:12:41
Old, I can guarantee you that there are at least two engines out there that the turpentine did nothing for, but neither did anything else. I ended up breaking the pistons out of one of them, the other one will soon have been soaking for two years, I will be patient for awhile longer.
old
07-18-2005 07:56:54
 Re: 530 stuck in reply to RustyFarmall, 07-18-2005 07:48:02
Ya it probably will not work on them all, some of them can be very bad off and just plan need to be pulled aprt and all new put back in to them
HH in AR
07-17-2005 18:19:03
If there's one any where I proly got It.
Harold
