Tractor Talk Discussion Forum
Cub 154
Harry Arnette
07-15-2005 05:17:08
I hav a Cub 154. I have gone to a great deal of trouble and expense to get a 3 pt hitch put on. Now I find that the PTO shaft turns the wrong way. I want to work a finish mower. Does any one have any advice.
cd in tx
07-17-2005 16:47:53
 Re: Cub 154 in reply to Harry Arnette, 07-15-2005 05:17:08
i have a 6' shreder with a gear box that turns the oppsite diriction the mower is junk but ill sell u the gear box for 25 bucks
504
07-15-2005 19:45:05
Harry,I know where there is a 160 with a junk pto but a good mower deck(heck the whole tractor is good but someone welded the pto solid.) Quincy IL
Bigdog
07-15-2005 07:03:14
Not only does it run in the reverse direction, it also runs at engine speed and is smaller and splined differently than a standard pto. You either need to buy a mower made specifically for the cub or you will need to make several modifications to what you have. As mentioned, blades for the opposite rotation can be purchased but you will need to make some pulley changes to compensate for the difference in speed.
There is a reducer / reverser available but they are hard to find and very costly. Also, it will likely not fit due to interference from your 3 point hitch.
john-mi
07-15-2005 06:32:32
I think you can get blades for opposite rotation.
