Tractor Talk Discussion Forum
What is an Farmall LP setup worth
martin d
07-13-2005 17:32:01
i have a running 49 farmall m that is currently running on LP but i switching over to gas.Is the LP stuff worth anything?
John A.
07-13-2005 20:25:23
 Re: What is an Farmall LP setup worth in reply to martin d, 07-13-2005 17:32:01
Martin, Like Sammy said- yes, but it depends on wheather the tank design on your tank looks like a add-on or looks like a factory design. ie steering rod goes through the tank and not over it.
The system would be more desireable it it has a real regulator and carb. Not the halfa$$ setup where the little 4 in. round gismo that is bolted to the top part of a factory gas carb. And the fuel line is routed along the edge of thr valve cover, so the engine heat is what vaporizes the fuel in the line. Hope this helps.
Later,
John A.
sammy the RED
07-13-2005 19:08:35
Yes !
