Tractor Talk Discussion Forum
250A belarus wont move
kenneth wheatle
07-13-2005 17:21:58
wont move when in gear, pto works fine, went forward then into reverse and didnt move. clutch seems to be fine, didnt know if there was a sheer pin or anything like one? have all manuals and didnt see anything about the problem, need help please. thanks
Jb
07-14-2005 07:50:18
 Re: 250A belarus wont move in reply to kenneth wheatley, 07-13-2005 17:21:58
Ken,
I doubt that your clutch suddenly failed. I have a Belarus 570 and don�t know if the transmission in your 250 works the same. If it does you very possibly have the transmission in neutral between the high and low speed selection. With the clutch in, move the stick shift to the extreme left and then push forward on the stick. You may be able to feel the transmission engage. Next pull the stick back slightly and you will find a neutral position. Next move the stick to the extreme right and push forward. That should be first gear. If that works you should be able to select the remaining gears as usual.
If this does not fix your problem, check the rear wheels and make sure that the large axle key between the clamps and the axle has not fallen out. If you are not sure what I am describing, have someone observe the axle while you engage the transmission. If the axle turns and the wheel does not, you have post the key.
You can contact either of these folks (and there are other places you can get parts) for a replacement key if you determine that is your problem. They can overnight the part if you desire.
Link
Link
Good luck.
Jb
07-14-2005 13:37:42
 Re: 250A belarus wont move in reply to Jb, 07-14-2005 07:50:18
Ken,
Note correction to the sentence "If the axle turns and the wheel does not, you have post the key." Should be If the axle turns and the wheel does not, you have lost the key.
ken wheatley
07-14-2005 15:35:30
 Re: 250A belarus wont move in reply to Jb, 07-14-2005 13:37:42
thanks jb ill give it a try after the rain quits. you are right about your clutch just dont quit. everything works, just doesnt move.
ken wheatley
07-15-2005 08:35:59
 Re: 250A belarus wont move in reply to ken wheatley, 07-14-2005 15:35:30
thanks a bunch, its fixed, caught between high and low range was the problem, wife said thanks too.
Jb
07-15-2005 09:02:45
 Re: 250A belarus wont move in reply to ken wheatley, 07-15-2005 08:35:59
Ken,
Glad your problem was corrected.
Good luck and regards.
Jim
