Tractor Talk Discussion Forum
3020 Carb Adjustment
Jd Family
07-13-2005 09:40:46
I am adjusting a carb on a 3020 gas.
There is an adjustment valve on the side which is brass, with a slot for a screw driver and then there is a valve type adjustment on the lower portion of the carb. What are these two adjustments for?
Thanks
msb
07-13-2005 19:26:02
 Re: 3020 Carb Adjustment in reply to Jd Family, 07-13-2005 09:40:46
The slotted screw is the idle mixture adjustemnt and should be adjusted at 600 engine RPM.Screw it in slowly until the engine starts to lose speed and the screw out until the engine starts to run too rich(rough) then split the difference.The screw on the bottom is the load speed jet adjustment.With the engine running at 2400 RPM, slowly turn the screw in until the engine begins to lose RPM.Then slowly turn the screw out ontil the engine starts to run too rich.Then split the difference.Since the two jets sometimes interact ,repeat the process and fine tune the adjustments.Be sure the engine is properly timed before making these adjustments.
Jd family
07-14-2005 15:31:08
 Re: 3020 Carb Adjustment in reply to msb, 07-13-2005 19:26:02
Thank you very much that is just what I needed to know and the steps you outlined will make this easy.
