Tractor Talk Discussion Forum
No Spark...any ideas?
D. Weeb
07-04-2005 16:52:43
I need help with a Kubota T1400. The engine turns over quickly but has no spark. I don't have a manual so I don't know where all the safety switches are located. Any ideas where to begin? It was running when the positive lead from the battery came off and the tractor quit. Does this model have an oil pressure safety switch.
If only this were a Briggs.
Thanks,
D
txgrn
07-05-2005 05:18:58
 Re: No Spark...any ideas? in reply to D. Weeb, 07-04-2005 16:52:43
On some machines like that which are magneto driven, there is a wire to the side of the coil on the magneto.
This wire does not "power" the magneto, it "kills" it by shorting to ground some of the turns.....when you want to stop the engine.
Do a quick check is to see if you have such a thing and if so, disconnect the only wire to it (besides the high voltage wire to the plug) and try to crank the engine. You will have to remove the air shroud covering the engine to get to the magneto which is mounted at the side of the flywheel on top of the engine.
If it cranks, with the wire removed, you have an interlock grounding your magneto when you don't want it to. Sorry, but the chase to find it can be confusing and cumberson. It includes seat, brake pedal, pto lever and ignition switch circuits.
To stop the engine (if you just got it running) you will have to either pull the spark plug wire off the plug (with a long dry stick or insulated screwdriver) or short out the terminal on the side to ground, or merely touch it with the wire you removed (which must be grounded or you could have started the engine).
Good luck,
Mark
