Tractor Talk Discussion Forum
601 work master
charles white
06-28-2005 06:01:47
I have a ford 601 workmaster that starts and runs great, until about using for 1 hour, the engine starts to run rough as if it isn't getting enough gas or mis-firing. It has new plugs and wires and points. Please help!
old
06-28-2005 07:21:00
 Re: 601 work master in reply to charles white, 06-28-2005 06:01:47
Sounds like you need to replace the coil. Pretty normal for a coil to act that way, run an hour or so then start to spit and sputter its almost always a coil going bad.
fluggie
06-28-2005 06:50:37
I would check to see how hot the coil is, assuming this is a gas, and then check fuel tank for debris, fuel lines, etc.
