Tractor Talk Discussion Forum
1944-2n Exhaust
Frank Hasapes
06-26-2005 10:24:38
I am currently running straight off the exhaust manifold. I want to put some exhaust system on but not sure which is best. What are your experiences of horizontal vs vertical and straight pipe vs muffler? Does the straight pipe really mean a notciable difference in power? I will be pulling a two bottom plow/disc and brush hog.
Leroy
06-27-2005 16:53:07
 Re: 1944-2n Exhaust in reply to Frank Hasapes, 06-26-2005 10:24:38
Also if you run a strait pipe start looking for a pair of hearing aids at $3,000+ and still not be able to hear and ran mufflers all my life, no pipes, 2 pair of hearing aids and neither pair work and still cannot hear
Leroy
06-27-2005 16:49:07
For the mowing go with the vertical exaust and you can add an extension pipe if it is too close to your face, but DON'T burn up that tractor and the underneeth exaust will burn up your right foot
Delbert from Lincoln
06-26-2005 13:31:13
I like the verticle after market exhausts. If you are mowing, brush hoging, etc, you can get a fire going on that exhaust under the tractor. I"ve read several stories about this happening, and seen one tractor that got burned up this way. Just something you might want to think about a while before you buy a new exhaust.
Bob
06-26-2005 13:43:38
 Re: 1944-2n Exhaust in reply to Delbert from Lincoln, 06-26-2005 13:31:13
Those are good points in favor of the vertical exhaust. However, as small as the tractor is, you sit close to the exit point of the vertical exhaust, and wind up with all the noise and exhaust gas in your face from the vertical system.
Steve Crum
06-26-2005 20:53:30
 Re: 1944-2n Exhaust in reply to Bob, 06-26-2005 13:43:38
I've made alot of the underslung (orchard)exhaust systems in stainless for these tractors and others. Patterns have been difficult to get as many of these tractors were converted to top exhausts early in life as most were used for light work such as mowing and raking, fires were a real concern.
Larry Allen
07-03-2005 19:23:05
 Re: 1944-2n Exhaust in reply to Steve Crum , 06-26-2005 20:53:30
are you bill crums brother from MO.
Steve Crum
07-03-2005 20:14:16
 Re: 1944-2n Exhaust in reply to Larry Allen, 07-03-2005 19:23:05
Not that I know of, I only had 1 half brother. I did have an Uncle Bill Crum from Pennsylvania, but he's long gone.
old
06-26-2005 12:02:57
On an N stright pipe will not help enough to be worth it, plus your ears will like the muffler. On an N the pipe and muffler should go down the right side under the pedels and out the back.
