Tractor Talk Discussion Forum
Manifold nuts leaking coolant - any fixes ?
Way Up Here
06-24-2005 03:59:35
Two of the 7 studs on a little Continental flathead have the studs threaded into the engine water jackets. These two studs were removed when taking off the manifold because the nuts were frozen on the studs. After reassembling the engine and running it, those two studs are leaking coolant. Any fixes? I have talked to some who recommend Devcon, JB Weld, Locktite, High Temp Silicon, Permatex gasket stuff, and even plumbers pipe thread dope (containing lead). Which one of these should I use, or is there something better yet?
wdtom
06-24-2005 16:24:48
 Re: Manifold nuts leaking coolant - any fixes ? in reply to Way Up Here, 06-24-2005 03:59:35
JAnd put the nuts on with a hi-temp anti-seize.
george md
06-24-2005 16:12:52
Remove the stud and nut , remove the nut from the stud , install the stud properly and with sealer, then install nut and torque to proper torque .
george
Way Up Here
06-25-2005 04:24:07
 Re: Manifold nuts leaking coolant - any fixes ? in reply to george md, 06-24-2005 16:12:52
Actually, I was asking as to what is the proper thread sealer to use.
george md
06-25-2005 09:06:58
 Re: Manifold nuts leaking coolant - any fixes ? in reply to Way Up Here, 06-25-2005 04:24:07
Most any sealer is good , if the stud is screwed in to where the threads tighten ,it becomes its' own seal much like a pipe thread .
george
Bob
06-24-2005 07:49:16
No big deal. Drain the coolant, remove the studs, clean and dry the studs and the holes. Reassemble with some good thread sealant, such as Permatex thread sealant. End of problem.
