Tractor Talk Discussion Forum
OT getting tires off rims
Joe Bloggs
06-20-2005 17:38:50
I have alot of old car wheels. they were used to make a retaining wall for a swimming pool. now I have a tire machine . it is old but it works fine on recently used wheels but with these old tires it cant break the bead. I have tried using the blade on the front of my tractor to do the job but it has not enough weight. any other ways of doing this job. I have about 500 wheels to remove.
mike langran
06-22-2005 08:19:00
 Re: OT getting tires off rims in reply to Joe Bloggs, 06-20-2005 17:38:50
what's the best way to fix the rims that are bent causing the air to leak out in a few days?
Leland
06-21-2005 12:14:10
If you really want a cheap easy wqay to pop beads #1 find a hi lift jack #2 place tire under the hitch of a heavy tractor #3 use jack to break bead by placing foot of jack on bead and lifting lip of jack under tounge slow but it works every time.
GP
06-21-2005 12:07:40
I have found that parking a 3/4 Dodge Ram with Cummins engine on the tire right up to the edge of the rim (rim should be laid hub face down) and then use a heavy 6 foot pry bar to pry up on the rim (jump on it if need be) is very effective at breaking stubborn beads. Flip the wheel over and repeat for the other bead. Not a real fast method, but it works.
dhermesc
06-21-2005 05:32:05
The sawzall idea is the best.
Rod F.
06-20-2005 20:25:54
You can use soapy water.... it helps. There are also commercial products out there for penetrating and lubing the bead. A product called Myers SKID is the most common that I am familiar with. For 500 wheels, it might be worth investing in a can. You can probably pick that up at an auto supply, or a heavy truck supply. I have also used LST penetrants, or any other good penetrating oil, although the spray cans can get rather expensive. With the Skid, and the tire machine, you should be able to get the job done. If not, then a bead maul will break them off. Just keep a tight aim.... Good luck.
Rod
Jake
06-20-2005 20:18:30
A lot of salvage yards have a machine similar to a wood splitter as other posters have described.
Go take a look at one, then go rent a wood splitter from your local rental center for a day or two.
Mabye try a couple wheels first. If the tires are rusted to the wheels they may be stuck on good.
Sounds like that may be your problem if they were used for a retaining wall.
MeAnthony
06-20-2005 19:48:01
If you're just looking to get rid of them, you might check for a tire recycler local to you. I only have about 30, and recently learned of a recycler within 1/2 hour drive. They will take them, rim or no, for $1(car/truck), $5 semi; a much better deal than $5(car/truck) each at the dump.
If you absolutely must break them down, you might try cutting the bead with a sawzall.
Joe Bloggs
06-20-2005 20:50:53
 Re: OT getting tires off rims in reply to MeAnthony, 06-20-2005 19:48:01
I can dump the tires for free. but they must be off the rim.these rims are rusty and the tires seem to be super glued on.I have never had so much trouble with a tire in my life as the 20 or so I have tried so far.
Leland
06-20-2005 18:38:10
Joe if you are out in the middle of no where burn them off some foggy night ,or the splitter will save you a lot of work.
Davis In SC
06-20-2005 18:18:57
Are you just going to scrap the rims??? If so... I have seen people use a woodsplitter to bend the rim, & tire pops right off.
old
06-20-2005 18:11:11
I use a tire hammer on almost all tires I play with, some have been on for 20 plus years. One big trick is to always pour some soapy water on the beads before you even try to brake them down. Also if you sort of dance on them after you pour the water on them it helps.
Joe Bloggs
06-20-2005 19:38:00
 Re: OT getting tires off rims in reply to old, 06-20-2005 18:11:11
I have tried with a tire hammer also. but with no success. I have alot of tires to do. I dont want to wear my self out. I am looking for an easy way. I have also tried putting a plank on the tire (like a ramp) and driving my truck up on it but no luck. so I went and put 1200 pounds in the back of the truck and tried again but the bead did not break . the tire was squashed flat by the weight but it was still tight on the rim.I dont have a log splitter.
old
06-20-2005 19:51:11
 Re: OT getting tires off rims in reply to Joe Bloggs, 06-20-2005 19:38:00
Well as one guy said you could burn them off but don't get caught. Around he its a big no no to burn tires. They also make a tire slide hammer which works well. Best thing I know to do is use a lot of water and soap.
jmh
06-20-2005 18:02:29
Hey Joe,
I use a Hi-Lift Farm Jack and chain to break down old tires. Works very good on old (50 yr.+) tractor tires. Has not failed me yet. jmh
Sean in Tn
06-20-2005 19:06:25
 Re: OT getting tires off rims in reply to jmh, 06-20-2005 18:02:29
Could you please explain how the chain and hi-lift work? Thanks
