Tractor Talk Discussion Forum
Eagle lift hitch on 401 Case
Bill Fosburg
06-20-2005 12:14:30
The manual shows the preferred third point over the pto stub shaft the alternate point is under the seat above the hydraulic levers. The length of the turnbuckle link is never right it usually jams nthr hyd. controls or the implement lifts a ways then tucks back under. Any help would be appreciated.
charles hess
06-20-2005 19:00:42
 Re: Eagle lift hitch on 401 Case in reply to Bill Fosburg, 06-20-2005 12:14:30
add to what George said you should have a top link that is ofset at tractor end to give more clearance
george md
06-20-2005 16:57:10
Bill,
The upper third point is to be used only
with pto driven 3 pt equipment. Lower third
point is proper for almost all equipment .
george
