Tractor Talk Discussion Forum
60 row crop
Mer
06-17-2005 10:53:39
I believe this is a 47, based on serial number. Found out they had ground reversed (had it negative). Now, I need to know about the coil. Does positive side gotwards the starter switch or toward the coil. The coil and the generator, volt regulator,distributor and starter are all delco reamy. The carb is a Marvel Schebce(?) Thanks
buickanddeere
06-18-2005 18:55:48
 Re: 60 row crop in reply to Mer, 06-17-2005 10:53:39
60's were built from 1952 to 1956. Power steering option from late in the 1954 model year. If the battery + is to chassis then the coil + goes to the distributer. Coil should be 3.0 ohm if fed 12V. Coil should be 1.5 ohm is supplied with 6V or used in a 12V system with a ballast resistor. Polarize the generator to be certain it isn't backwards.
old
06-17-2005 11:14:55
On a - ground system the + side goes to the switch on a + ground system the - goes to the switch.
