Tractor Talk Discussion Forum
advice on sweet corn
ppery
06-15-2005 18:48:24
i planted a small plot of sweet corn for my first time.. it looks like its doing good so far. do i need to spray for bugs?? or is their anything else i need to look out for?{coons,birds,etc?} if i need to spray, when do i?. thanks.perry in south east michigan
wolfman
06-16-2005 17:44:21
 Re: advice on sweet corn in reply to ppery, 06-15-2005 18:48:24
Used to raise about 5 acres of sweet corn. Had 4 box traps baited with hostess ho-ho's & similar sweet yukky stuff. If the traps had sweet geuy stuff sweeter than the corn, you got em. Groundhogs liked apples (one trap got that bait). Groundhog eats a few ears; A coon will strip the whole field. Careful not to plant super sweet beside regular sweet or it'l all be super flat. Baited traps in evening; usually needed 3 shells early next morning.
buickanddeere
06-17-2005 01:29:17
 Re: advice on sweet corn in reply to wolfman, 06-16-2005 17:44:21
Darn. I plated the four sweet corn varieties in two rows each for a total of 8 rows together in one patch. May as well let the coons have it. I did know enough to plant the ornamental corn a couple of hundred feet away and down wind of the sweet corn. In this politically correct age we can't call it Indian Corn anymore. I have the live trap set outside the turkey run at the moment, baited with peanut butter, jam and marshmallows. Caught 7 of my own turkeys in 8 days. It appears the old fashoned bronze turkey can fly over fences a white hybred turkey can't.
riverbend
06-17-2005 20:03:04
 Re: advice on sweet corn in reply to buickanddeere, 06-17-2005 01:29:17
You might need 4 rows of each variety to get good pollination. Don't give up yet, if the maturities are different, it might work out okay.
Indian corn, Mandan Bride, in particular, makes the best tasting corn meal. IMHO.
riverbend
06-15-2005 20:35:38
Start live trapping and shooting coons as soon as you care to. You must check your trap every morning. There are only so many coons in your area and thinning them out will help. Otherwise you can put up three strands of electric fence. 3", 6" and 36" off the ground. The first two are for the coons, the third one is for the deer.
If you can stand to trim off the wormy tips, you will not need to spray.
Bob
06-15-2005 21:23:44
 Re: advice on sweet corn in reply to riverbend, 06-15-2005 20:35:38
How about the moose???
DON L C
06-15-2005 19:19:13
ppery --- we used to put out a plot about 150ft.(row length) x 300ft for our oun use...we planted it on a off-set corner of one of our fields...all we did was fertilise when planting....cultivated when the field corn got it.....only problem we had ws Racoon.....plant about 12 rows every weeek, until you run out of space....don't pick it until you are ready to eat it...(20 min..).....
Don S-W Ohio
pperry
06-16-2005 03:50:18
 Re: advice on sweet corn in reply to DON L C, 06-15-2005 19:19:13
thanks for the advise ,ill have to do something with the coons, we have alot of them.
