Tractor Talk Discussion Forum
Stuck oil pan any trick to get it off?
oil pan dan
06-15-2005 14:16:43
My oil pump is clogged and I can't get the oil pan off. I don't want to bend the pan and prying on it does not seem to be working, is there a trick to getting it off or do I just keep prying at it.? Thanks Dan Ca.
JHesler
06-16-2005 07:25:34
 Re: Stuck oil pan any trick to get it off? in reply to oil pan dan, 06-15-2005 14:16:43
Melt the permatex with a torch.
TDK
06-15-2005 22:00:24
I believe there are 18 - 5/16 bolts and 1 nut holding the pan. Count the ones you've removed. There's 3 in the rear that's sometimes overlooked.
Mike M
06-15-2005 18:45:34
How do you know the pump is clogged if you can't get the pan off to look ????? Anyhow I'd check the oil pump cover for warpage and blowed gasket,and shaft for wear I have had several Farmalls leak off oil pressure there.
oil pan dan
06-15-2005 16:45:43
this is a farmall 300 utility. Thank you for your help I'll keep on trying but not prying. Dan Ca.
Russel
06-15-2005 16:29:27
Off what? There is a big difference between a pan on a farmall M and a ford explorer
Dixieland
06-15-2005 16:16:45
Sounds like someone used some kind of sealer on the gasket. Do as suggested with a good narrow putty knife and be patient.
roper6365
06-15-2005 17:37:18
 Re: Stuck oil pan any trick to get it off? in reply to Dixieland, 06-15-2005 16:16:45
Yep, sounds like someone got heavy handed with a tube of permatex. You can even tap the putty knife with a rubber hammer. I hate that stuff.
Good Luck
Weirsdale George
06-15-2005 15:27:23
First, make sure you have located and removed all the bolts. Usually there are a couple hidden
right up in the corner next to the rear and front main bearings. After that, try driving a sharpened putty knife between the pan and block in as many places around the perimeter -- don't pry, that's whats distorts the sheet metal.
