Tractor Talk Discussion Forum
Tractor stopped charging (again!)
Brett in KS
06-14-2005 20:52:49
Hi,
My D19 is not charging again. It stopped charging last spring. It stopped charging one day when I was blading snow. I shut if off and went inside and an hour later went out to finish the job. It wasn't charging when I started it back up, but 15 minutes later it was charging again. It seemed like it would only charge when it wanted to. Then a couple of weeks later, it stopped charging altogether.
I went and bought a new voltage regulator and installed it. after polarizing it, I started up the tractor and it wouldn't charge. I took the (new) voltage regulator and the generator to John Deere and had it tested. They said the voltage regulater was bad. I got a new one and installed it. I polarized it and started it up. It was finally charging! I put it in the shed (this was last week.) Today, when I went to move bales, I got it out, and it was charging fine. I pulled up to the bales and glanced down and the ammeter and the darn thing showed a slight discharge. I then drove it over the the shop and on the way there, it started charging again. I tested the voltage at the battery with a multimeter and if I remember right the voltage was about 13v. I shut it off and turned it back on. It didn't charge after that.
Running, the voltage at the batter is 11.9-12.04v . Voltage on the "A" terminal or Gen terminal on the voltage regulator said about .5 v. What is it supposed to be? Does that mean it is charging a little, tiny bit? Does the regulator need adjusting? I know I polarized the regulator and generator when I installed them, and it was charging after that. All the terminals have been clean and the connections are good. I'm out ideas. Does anyone else have any?
Thanks in advance.
Brett in KS
06-15-2005 06:39:55
 Re: Tractor stopped charging (again!) in reply to Brett in KS, 06-14-2005 20:52:49
I put new brushes in the generator a couple of weeks ago. (It is a 2 brush generator.)
What is the voltage that the generator is supposed to put out?
Hermit
06-15-2005 19:03:18
 Re: Tractor stopped charging (again!) in reply to Brett in KS, 06-15-2005 06:39:55
The .5 volt tells me the field is not being built up. At medium to high rpm, the output should be around 13.8 volts. It does sound like a loose or broken connection or wire. Adjusting the regulator is a bad idea unless you have some special test equipment. Try to get your hands on an older Motors manual. It has good troubleshooting information depending if your generator is internally or externally grounded, proper polarizing based on type of generator and isolating the area of the problem.
Brett in KS
06-18-2005 06:03:28
 Re: Tractor stopped charging (again!) in reply to Hermit, 06-15-2005 19:03:18
Thanks! I'll take the gen off and take a look.
Hermit
06-15-2005 05:35:08
How are the brushes? If this is a three brush generator, I would check the field brush and it's spring first then the field wiring.
Jason Simmerman
06-14-2005 23:01:45
Had a problem like this once before on a Farmall. Make sure the terminals on the generator are not shorting out onto the generator housing. Could also have a broken or bad wire in your harness. Check the resistance of your wires in your harness if your multimeter has the ability to. From end to end on each wire you should have no more than 1.0 ohms of resistance. Shake the harness around and see if it changes much. Anything more than that you have a wiring problem.
