Tractor Talk Discussion Forum
1999 ford f250 p s
bplott
06-11-2005 04:05:51
good morning Have queston. looked at 99 ford ps pice was 16,000. clean g neck ex cab 90,000 miles is it priced about right. any problems with this motor or trans? thanks bill
JT
06-11-2005 08:55:12
 Re: 1999 ford f250 p s in reply to bplott, 06-11-2005 04:05:51
has it had the cam sensor replaced yet, or water pump, or the glow plug switch replaced or somekind of sensor in the fuel filter bowl.this is some of the things I have had to do to my 2000 F250 SD PS. Heard this was common, have no proof, just hearsay. As for value, go to Kelly Blue Book(KBB.com) and you can plug in all the info on that unit and get a rough guess on price.
caseyc
06-11-2005 09:18:18
 Re: 1999 ford f250 p s in reply to JT, 06-11-2005 08:55:12
everything you listed is comman but you forgot the injector o-rings, they go out and dump fuel in to crankcase. if you don't catch it soon enough you get to buy an engine. once they've been done your good to go for along time. ball joints are another problem we've been running into. they are just like any other truck, when you use them stuff will break/wear out. some things were a poor design to start with but every vehicle has it's problems. on a brighter note though for as many power strokes that have had problems that i know of there is an equal number that havn't had a lick of trouble!
casey
Farmered
06-11-2005 05:41:19
You didn't say which engine and transmission it has. If it has a motor it will take a long extension cord to run it. I'd say you could do better than $16,000 no matter how it is equipped. Ed
Joel Harman
06-11-2005 05:40:36
be prepared to replace clutch soon. Center ring that holds the springs in falied at 55K on a 350 of mine. Still had 90% of clutch left. I got over making tires spin when I was about 17 so was not from abuse.
