Tractor Talk Discussion Forum
OT,Perma-Column use in pole building
Tim,Ohio
06-10-2005 05:59:10
I was wondering if anyone has experience
with this precast concrete column used below grade for construction of a
pole barn?
Link
Does anyone know the cost?
I have been searching the web and have not found suppliers displaying the cost.
Likely expensive, but wonder if the extra
cost is worth it. I imagine if it is still
less expensive than a footer, concrete block foundation and stick framing(and last as long), then it would be worth it. Any comments welcome and appreciated from those with construction experience.
Tim, Ohio
evilboweviel
06-10-2005 10:11:54
 Re: OT,Perma-Column use in pole building in reply to Tim,Ohio, 06-10-2005 05:59:10
where at in Ohio?
I am Lancaster, Ohio 43130
Ron
Tim, Ohio
06-10-2005 10:20:04
 Re: OT,Perma-Column use in pole building in reply to evilboweviel, 06-10-2005 10:11:54
Ron,
I am up between Zanesville and Newark.
Tim, Ohio
Tim, Ohio
06-10-2005 08:35:08
 Re: OT,Perma-Column use in pole building-cost in reply to Tim,Ohio, 06-10-2005 05:59:10
I did just call a supplier. For the
sake of letting all of you know, the concrete
portion (without any lumber) is:
70.00 per part. This was for using
3, 6x6 lumber sections on top of the
column, making a 6 x 6 pole. I guess
a 10' section of lumber would give you a total of 15' to work with (in my area
that would be about 12' foot walls).
I'm guessing adding the lumber cost would bring the whole part to about 90.00 per pole.
Tim, Ohio
Lou
06-10-2005 08:43:55
 Re: OT,Perma-Column use in pole building-cost in reply to Tim, Ohio, 06-10-2005 08:35:08
Tim A few years back I buildt a pole barn, Used sona tubes under ground filled with quickcreet, with a metal bracket to hold the 6x6 post, dont believe it came to $90. per. good luck Lou
Jerry Cent. Mi.
06-10-2005 15:29:20
 Re: OT,Perma-Column use in pole building-cost in reply to Lou, 06-10-2005 08:43:55
My neighbor just built a building and it was recomended that he just bury the poles without any concrete around them. He claimed that the poles will last longer.
