Tractor Talk Discussion Forum
Onan 18hp B48M-GA018 engine
fletcher
06-07-2005 22:04:26
Hello, I have a Case/Ingersoll garden tractor with a 18 hp Onan engine. The engine is hesitating/misfireing during idle and open throttle operations. This condition is noticeable from near start-up and get worse under longer operating periods. At first it would take 20 to 30 minutes for the misfireing to start, followed by back fireing. I have replaced the ignition coil with two different used coils but still have the same problem. The engine has 544 hrs on it with the original points and condenser installed. I replaced the plugs last fall when I was having this problem but I am not sure if I set the plug gap. I think maybe I can rule out an ingition coil problem. That leaves a condenser, points, or plug gap problem! If anyone has an more insight or comments on this problem, I would like to get your thoughts! Thanks, Dan
Giles
01-16-2006 16:09:41
 Re: Onan 18hp B48M-GA018 engine in reply to fletcher, 06-07-2005 22:04:26
I had a simular problem with a different Tecumseh engine. The vales were to tight I set them at .010 because I had no book. Most of the stuff I've worked on is ususally between .008 and .012 If they get tighter after warm up it will get worse.
Giles
chris sweetland
06-10-2005 19:29:55
had the same problem on mt bolens 1886 i put on a ground strap and it runs very well nowmake sure you have a good ground to the engine they sometimes sit on rubber mounts... hard to get a ground through them
Big Bo
06-08-2005 09:06:36
I had a JD 316 with a Kholer engine that did the exact same thing. JD dealer did a valve job on it and ended the problem. I"d try the electrical route first, though. Could save you a bunch of money.
old
06-08-2005 08:11:09
I'd replace the points and condenser and see what happens, cheap fix and it never hurts to replace them every once in a while any how. You could also have a problem with the carb or even if it has one the fuel pump.
hlc
06-08-2005 04:07:37
I had a car once that did this and it had a bad condenser. I have see spark plugs do this. Also suspect would be a bad intake valve. This could cause gas to be sucked into the cylinder at the wrong time when the valve should be closed.
