Tractor Talk Discussion Forum
JD 2140 sg2 rockshaft acting up
Aussietractor
06-06-2005 20:04:14
Here's one for all the hydraulic gurus out there. I,m having trouble getting the three point linkage [TPL} to "float" properly.According to the JD owners manual to get the TPL to float the rockshaft selector is placed in the minimum position and push the rockshaft control lever all the way forward.
As soon as I push the rockshaft selector to minimum the TPL raises to full height no matter which position the rockshaft control lever is in [ie raise or lower].
I can get the TPL to partially float by placing the rockshaft selector lever in the maximum position and placing rockshaft control lever in the forward [lower] position.
Having said that the rockshaft selector lever seems to be operating in a reverse mode. Anyone got any ideas on this?
Aussie tractor
06-07-2005 17:03:15
 Re: JD 2140 sg2, rockshaft acting up in reply to Aussietractor, 06-06-2005 20:04:14
Ok you blokes, Whats going on out there, have I got all of you stumped-[Aussie for "don't know"]. I hope I've got you scratching your heads and searching back through the old brain cells.
Would I be better of a another forum?
david val
06-08-2005 05:19:34
 Re: JD 2140 sg2, rockshaft acting up in reply to Aussie tractor, 06-07-2005 17:03:15
your manual is right, of course.
the minimum you need is linkage adjustment: make sure your max-min arm on the rockshaft housing is doing it's full movement(stop to stop), if not- adjust. next put in min position and check valve neutral (if i remember well should be around 10 mm between raising and lowering on console. if adjustment needed write to me for a special description). next adjust turnbuckle (or rod on later models0 so that rockshaft lifts and lowers all the way.
david
Aussietractor
06-08-2005 15:25:12
 Re: JD 2140 sg2, rockshaft acting up in reply to david val, 06-08-2005 05:19:34
Thanks David, I was beginning to think that I had everyone stumped. I will check out what you've said and let you know how I got along.
Greg.
