Tractor Talk Discussion Forum
Help-dead and wet tractor
Kajun
06-06-2005 09:24:26
Tractorfolk:
Washed down JD 790(diesel) on Saturday. Sprayed off whole trac with garden hose after soaping down ,etc. Now trac won't start. Nothing at all when turn key . Normally at that point the idiot lights on the dash come on . Lights will not come on either. Trac mechanic friend says can't figure ; must be coincidental , he says.
Any ideas? All fuses are okay.
Kajun
devildawg(tx)
06-07-2005 17:50:31
 Re: Help-dead and wet tractor in reply to Kajun, 06-06-2005 09:24:26
Bad fusible link wire coming from stater feeding gauges solenoid etc.? Where does the voltage end?Bust out the test light and wiring diagram.
Kajun
06-07-2005 06:52:45
Thanks for all the suggestions. Cleaned battery and terminals when I first got trac. Still clean and well greased. Ground wire was badly worn,maybe that's the issue. Raining now in Louisiana and it'll need to stop before I can work on it. Gonna try all your ideas. Much obliged.
Kajun
RickB
06-06-2005 14:05:08
NH compacts have a fusible link at the battery connection on the starter solenoid. It protects EVERYTHING except the actual cranking current. Look for something similar on the Deere.
RayP(MI)
06-06-2005 11:20:38
Had that happen once on a car engine I washed down. There was aparently enough salt and sulfuric acid on and around battery to allow it to discharge - completely. Suggest you remove battery clean it up thoroughly, dry completerly, clean terminals and clamps and reinstall. Charge it as necessary.
Indydirtfarmer
06-06-2005 09:46:26
Battery connections or ignition switch (????)
aussietractor
06-06-2005 09:38:18
Kajun, Check output of battery
Allan in NE
06-06-2005 09:26:58
Dirty battery connections?
Allan
RP
06-06-2005 18:58:08
 Re: Help-dead and wet tractor in reply to Allan in NE, 06-06-2005 09:26:58
Yeah, I had a Buick Regal that would go completely dead after running through a big puddle. It would barely run the dome light.
Clean the battery terminals
