Tractor Talk Discussion Forum
compressor motor
37 chief
06-05-2005 22:12:09
My 220 V single phase compressor motor finally stopped working.I have a good 5 hp 3 phase motor. There is a way to convert single phase to three phase, by running another motor seperate from the main motor. Has any body done this? I have a phase convertor on my log splitter, but they are almost as expensive as a new motor. Thanks for any info. You don,t realize how much you depend on your air compressor until it breaks down. Stan in calif
Bob
06-06-2005 08:13:17
 Re: compressor motor in reply to 37 chief, 06-05-2005 22:12:09
There's TONS of phase conversion information on th Practical Machinist BBS, linked below. The forum linked is specifically for phase conversion and Variable Frequency Drives. Try a search there.
That being said, due to high starting torque needed, an air compressor is probably NOT the best candidate for a phase convertor, although if the compressor has an unloader for easy starting, it would probably work.
aussietractor
06-06-2005 07:40:10
Stan, do you mean you want to convert 3 phase to single phase? if yes it can be done, I have a brother who is a motor rewinder and have seen him do this type of magic. Needless to say this sort of thing is best left to an expert, so consult a rewinder for advice, costings etc. This initial advice should not cost.Good luck.
aussietractor
06-06-2005 08:16:21
 Re: compressor motor in reply to aussietractor, 06-06-2005 07:40:10
Stan, I was just thinking that it might be just as easy and cheap to get your old single phase motor fixed as against messing around converting 3 phase motor. It might be a simple repair job, No messing about modifying mountings either. Good luck again.
