Tractor Talk Discussion Forum
super 706
elk
06-05-2005 15:13:18
whats the trick to makeing a 414, out of a 1066 fit in a 706. we need a pulling tractor with some juice.
Redman
06-05-2005 18:30:21
 Re: super 706 in reply to elk, 06-05-2005 15:13:18
no tricks to it,take the 414 out of the 1066 and bolt it to the 706 rear-(the rear engine cover will hang out about 3/4 of an inch on each side easily fixed with a grinder and a little time)
get the front cover off a truck and bolt to engine and make plates to go from the 2 outer holes on each side of the block to the frame rail.
get the radiator from the 1066.
throttle linkage from the 1066.
1066 clutch too,might want to do that first!
might be something that i'm forgetting,but that is pretty much it.
RickB
06-06-2005 02:53:32
 Re: super 706 in reply to Redman, 06-05-2005 18:30:21
Are you saying a 282, 310 and 414 are all the same length, or they are not and it doesn't matter?
RickB
06-05-2005 17:02:12
Search the archives on the pulling and Farmall boards here. This comes up all the time. For starters, the 414 is longer than both the 282 or 310 so the frame rails and hood are problematic. I think the rails are too narrow as well, but that may not be serious.
