Tractor Talk Discussion Forum
Large Kubota tractors
Huw from West W
06-05-2005 12:23:13
How good are the 80 and 90 pto horespower kubota tractors only just started selling them here in the UK . Went to look at one with my brother in law the other day seem good and simple not too much fancy electronics.
Bill(Wis)
06-06-2005 05:29:39
 Re: Large Kubota tractors in reply to Huw from West Wales, 06-05-2005 12:23:13
Are you looking at M8200 & M9000? Those are 82 & 90 HP (eng). They manage to get more HP out of 202 cu in than anybody else through a combination of turbocharging ad intercooling and RPM and very high quality. Stingy on fuel too. They are a bit lighter than competition but that can be a plus and you can always make them heavier.
Hugh MacKay
06-06-2005 01:58:23
Huw: I had an opertunity to operate two different Kubota tractors. First one was a 6950, I think around 70 hp. I forget model number on 2nd one 85XX, and I understand it was about 90 hp. Both these tractors were 4x4. I probably put about 600 hours on each of these tractors. I must say I was quite impressed. The manuverability for that size of 4x4 was truly amazing. They both seemed to have the rated hp as advertized, transmissions were convenient to use and had good speed selection. Hydraulics worked well on both. Now that is quite a testimonial from a dyed in wool IH man.
I guess what I'm telling you is these tractors from a handling and operation point of view, came as close to the old IH 06, 26 and 56 series, as anything I've operated. Your right not a lot of sophisticated electronic gadgets either. I have also operated both new CaseIH as well as John Deere, neither of which impress me as much as the Kubota.
I do know Kubota had problems with sheet metal on the older 6950 models. It seemed to rust under the paint and tractors tended to look quite shabby even at 5-10 years of age. I think this problem has been cured.
Would I buy one? Definately, if I were still farming and the price was competive. Mind you competive could be 5% to 10% higher than anything else I've operated new in the past 10 years.
rettchr
06-05-2005 16:38:18
I have an M5700 (<60Hp and smaller than your query) but am happy with it. I talked with a dealer who has sold several of these larger machines and he reported his customers were satisfied. I have about 200 hrs on mine and no troubles to date.
This M5700 replaced a MF 165 gas tractor; the Kubota uses literally half the volume of diesel fuel that the MF did of gasoline for the same work.
Ken Macfarlane
06-06-2005 05:54:22
 Re: Large Kubota tractors in reply to rettchr, 06-05-2005 16:38:18
They are a basic tractor, not a lot of fancy stuff but the M100/M120/X series are moving that way with powershift etc.
They have good following here as the reduced electronics make them pretty reliable. Many friends here have NH's and are constantly battling wiring and bad solenoids.
