Tractor Talk Discussion Forum
can you put a sleeve hitch on a 1978 GT 19.9 twin
warren driggs
06-02-2005 17:29:30
I am tring to find out if you can put a manuel lift sleeve hitch system on a 1977 or 1978 sears GT 19.9hp twin garden tractor it doesnt have the 3 point hitch anymore.and where i can find the model number havent found it yet or any other information about these tractors i havent seen much on the net. about them
JoeK
06-02-2005 18:38:26
 Re: can you put a sleeve hitch on a 1978 GT 19.9 t in reply to warren driggs, 06-02-2005 17:29:30
Sears doesn't make em,so we have to determine the mfg that actually built it.Sears tractors are currently built by a division of Electrolux Intl,but in the past have been Murray,MTD,AMF,David Bradley,Roper and others.Attachments were mostly Haban built.The Sears model no xxx.4567890 prefix will tell who built the unit.Check frame rails,under seat or rear end beneath/behind seat.Probably was a foil sticker :(
warren driggs
06-02-2005 18:42:06
 Re: can you put a sleeve hitch on a 1978 GT 19.9 t in reply to JoeK, 06-02-2005 18:38:26
i found the model number finaly it is917257080
JoeK
06-02-2005 19:13:50
 Re: can you put a sleeve hitch on a 1978 GT 19.9 t in reply to warren driggs, 06-02-2005 18:42:06
OK.that unit was built by Roper/AYP(American Yard Products).As it is a GT(garden tractor)vs an LT(lawn tractor)it should take a sleeve hitch w/o modifications.Sleeve hitches run appx $120 at Sears and with your tractor number they should be able to provide one or point you at a supplier.I believe Roper/AYP was absorbed a couple yrs back by Murray which is now out of business also,but if sears can help,you might try calling Murray...I underswtand the recievers are providing short term in stock parts and tech help.
warren driggs
06-03-2005 16:52:40
 Re: can you put a sleeve hitch on a 1978 GT 19.9 t in reply to JoeK, 06-02-2005 19:13:50
thanks for the info i really appreciate it
