Tractor Talk Discussion Forum
gas leak on the new red paint!
kjm
06-01-2005 20:14:42
The problem is the sedament bowl turns in to far and is 180 off,has anybody tried to solder the threads and recut them or will the pot metal melt first? I have alread tried thread tape and sealer it just starts to leak again after a day or two.
timm
06-03-2005 21:55:09
 Re: gas leak on the new red paint! in reply to kjm, 06-01-2005 20:14:42
paint it green then it wont peal
williamf
06-02-2005 18:46:29
I was thinking when I read the title that I might have a suggestion. I see now that it's the leak, not the paint. What the heck, why pass up a chance?
I had a problem with gas splashing out around the old cap on my Farmall's gas tank. Made a black stain in the less than top grade paint that the P.O. had used. No amount of washing, PB, WD-40, nothing would get it out. I found an old can of rubbing compound left over from when my sister's cow rubbed her horns all up and down the sides of my now ex-wife's Challenger....'Nother story.
Anyway, that did the trick. Paint around the gas cap looks better than most of the tractor. And I got a free gas cap from.... 'Nother story, too.
Wm
Mike M
06-02-2005 09:49:47
If you are sure it is leaking at the threads and you also don't think it will take the extra tightening without breaking ,then get some permatex #1 the hardening kind and use this on the threads then screw it in to where you want it and let it sit and harden for a day. This should work fine as this is what it is made for.
GregCo
06-02-2005 08:09:06
I have used a product called Gasiola for this sort of thing. It works great.
Nebraska Cowman
06-02-2005 03:19:42
I'd buy a new sedement bowl assembly. The last ones I got from case IH were less than $30
Zim
06-01-2005 21:25:17
Maybe there is a brass union/turnbuckle that could work with those threads. You'd want to use a neoprene seal if applicable. It might be worth checking into at a good plumbing, hardware, or automotive store. Good luck!
Bob
06-01-2005 20:45:28
Get some thread goop approved for gas/peteroleum use.
Davis In SC
06-01-2005 20:42:45
Would tapping the hole a bit deeper work??? So that you can tighten it another half turn .....
msb
06-01-2005 20:42:30
Not sure but I think NAPA has some thread sealer that hardens and fixes leaks like this.----- -Didn't we used to use white lead for things like this?
