Tractor Talk Discussion Forum
Simplicity Lawn Tractor
ElohimJr
05-31-2005 20:44:54
My neighbor has a Simplicity lawn tractor that gas is getting in the oil. No one has found out why. He showed me the manual which says that it is a 12.5 hp either 5212.5 H or 5216 H. Can anyone tell me how to solve this problem?
Thanks
JoeK
06-01-2005 18:56:53
 Re: Simplicity Lawn Tractor in reply to ElohimJr, 05-31-2005 20:44:54
Most common cause is carb float setting...not closing needle valve,allowing raw gas to weep into the cylinder past the rings when not running.
doogdoog
05-31-2005 22:29:24
Aloha, Not knowing the tractor, but if it has a mechanical fuel pump, maybe the diaphram is ruptured and is leaking into the crankcase.
Mahalo,
doogdoog
Loren
05-31-2005 22:09:36
You may want to go to Simple Tractor website also.
