Tractor Talk Discussion Forum
Yazoo YR48 deck support spring
Nate Powell
05-28-2005 08:36:00
Have a YR48. I broke the spring connecting tractor to deck. Also need frame ring than spring attaches too. Current ring is not made to be removed, but is nearly worn through where spring attaches. . .so replacement will have to be able to be open to fit around frame tubing. Know where I can buy replacement? Thanks!
Ia Roy
05-28-2005 21:35:33
 Re: Yazoo YR48 deck support spring in reply to Nate Powell, 05-28-2005 08:36:00
I have a YR48 and checked the internet for a link to dealers several years ago. The old dealers should stilll have a source of parts. They were bought out and renamed Yazoo-kees I believe. I think they were bought out again since then. I think the owner is the same as the Husky chainsaws and garden tractors. The other thing you could do is measure the diameter of the wire, and the outside diameter of the spring, and look for spring manufacturers with those specs.
