Tractor Talk Discussion Forum
stuck motor
Larry806
05-27-2005 14:30:31
third party image
I enjoy reading the stuck motor threads. I get a kick out all the just soak it in oil a few days & use a pry to turn it over. I must work on a lower class of junk maybe 1 out of 10 I work on that works. This is from a 27 JD D I removed the block & pistons as a unit. I sandblasted the built up rust from above & below the pistons. Lets just say it was most of what my 120 ton press wanted to do to push them out. I wonder how long I would have had to soak these? I wreckedm I"d need a pretty long pry bar too><~
txgrn
05-28-2005 05:40:59
 Re: stuck motor in reply to Larry806, 05-27-2005 14:30:31
Interesting thread. I agree with your comment "I must work on a lower class of junk maybe 1 out of 10 I work on that works."
If mine don't respond to the soaking I start looking elsewhere for a candidate tractor.
Bravo for your perseverence and injenuity.
Mark
Redmud
05-27-2005 18:15:01
Larry, there are engines that you could pi$$ in the cylinders and get the same results as PB blaster, WD40, ATF, or Diesel fuel. Then there are engines that the above product might help, if you have a large press.
old
05-27-2005 16:05:01
Tranny fluid etc. doesn't always work, but so far I have never found and engine that I haven't been able to unstick. Guess I have always been lucky.
Larry806
05-27-2005 14:31:52
third party image
As I said it took a pretty hard push to get them out I had a half inch steel plate on top of the piston I used a 4x4 on top of that . It pushed so hard it bent the steel plate down in the middle & took the top of the piston out
