Tractor Talk Discussion Forum
Radiator leak on JD model 50
Rags
05-25-2005 18:34:41
Is there a product on the market that will stop a slow leak in a radiator? Thank`s.
Jb
05-26-2005 09:29:14
 Re: Radiator leak on JD model 50 in reply to Rags, 05-25-2005 18:34:41
I have used Bars Leak in a number of vehicles including an International 444 tractor. It has worked every time and has been in the International approximately 15 years and still holding with no ill effects. You can find it at Wal-Mart or any auto parts store.
TomTX
05-26-2005 07:05:49
Just my opinion. In olden times I have used about every stop leak product out there, and in ALL cases I would have been better off and spend less money in the long run if I had pulled the radiator and had it fixed right.
really jd-tractor
05-25-2005 20:36:33
Ground black pepper,mix w/a little antifreeze as a slurry and pour in while warmed up and run awhile,about 5 tablespoons in a B worked real well ,it is cheap,works and causes no harm.coarse ground works best
Nebraska Cowman
05-25-2005 20:01:48
Oh yeah, some guys will tell you not to use it but i have had good results with the aluminum powdered sealer, you buy it in a little plastic tube for about 99�. even wal-mart has it.
