Tractor Talk Discussion Forum
2n blowing water
ps
05-25-2005 17:27:55
whenever i put a strain on my 2n it will blow steam or water out rad cap this only happens when it has severe strain on it 1 time it blew out when i started it cold any ideas? blow head gasket stuck thermostat crappy water pump? thanks for any help
Big Bo
05-26-2005 09:52:22
 Re: 2n blowing water in reply to ps, 05-25-2005 17:27:55
My 8n did the same thing. Fellows over on the "n" board clued me in to the n series radiators being WAY over engineered and are easy to overfill. I was filling it to the top with coolant and when worked hard would spit coolant. Now I keep the coolant level down 3" or so from the top and have had no problems since. This may or may not be your problem, but cured mine.
WRENCHTURNER
05-25-2005 19:17:05
JUST A THOUGHT-EVER REPLACE THE RADIATOR CAP? THEY HAVE TO MAKE A GOOD SEAL TO PRESSURIZE THE RADIATOR SO THE COOLANT DON'T BOIL AT TOO LOW A TEMP. MOST ARE MARKED AS TOO WHAT PRESSURE THEY ARE AND A TESTER IS AVAILABLE TO CHECK THEM, BUT THEY ARE SO CHEAP I USUALLY JUST BUY A NEW ONE.
ps
05-26-2005 19:06:47
 Re: 2n blowing water in reply to WRENCHTURNER, 05-25-2005 19:17:05
water level is 2 3 inches lower then top of rad and it has new cap but that ads another ? the new cap is 1 of those fancy ones makes it look good but the cap has no rubber seal on it.look at the others and they didn't have one either? thanks for the help anyways
ps
05-26-2005 19:10:55
 Re: 2n blowing water in reply to ps, 05-26-2005 19:06:47
the most confusing thing is when i started it and it blew water out and the tractor water cold?and when it do's it the temp is around 110 115 never overheats just blows water
