Tractor Talk Discussion Forum
8n
als
05-24-2005 16:02:20
my 3pt. hitch wont go down
any info on rebuilding the pump?
Gene Davis (Ga.)
05-24-2005 20:59:57
 Re: 8n in reply to als, 05-24-2005 16:02:20
The hydrualic pump normally has no influence on a 3pt hitch down cycle. It usually supplies lift force to the upside of a single action cylinder for lifting. If you had a double acting lift cylinder hose into each end, then you would need pressure to push it down. however, the 8N Ford has an internal single acting lift cylinder.Down is usually by a spring or gravity. Look for a possible stuck control valve if it will go down when engine is shut off. If not able to push it down by hand with engine off, check for bent or binding in hitch parts.
