Tractor Talk Discussion Forum
carburetor question
carb
05-23-2005 09:15:25
Running a 24 hp Linamar Engine yesterday. Engine started surging. I did the simple stuff. Changed the fuel, inline fuel filter and cleaned the air filter. Engine still surged. Opened the choke about 20% or less and engine smoothed out at operational rpm. Looking for ideas on what I need next to check? Idle rpm is rough now as well (no choke).
Thanks
Jerry/MT
05-24-2005 13:07:09
 Re: carburetor question in reply to carb, 05-23-2005 09:15:25
Surging is usually the result of an over lean mixture. Make sure that your carb jets are clean and the right size.
Bob988
05-23-2005 16:17:46
My Farmall would run only part choke. It would surge and sputter if choke was opened up all the way. Soaked and cleaned and rebuilt carb twice and still bad. Bought a brand new carb and fixed the problem.
Kendall
05-23-2005 09:28:52
Sounds like crud in one of the carb jets. May be time to take it apart and clean it out. A tiny wire will help clean out the jets. May also be simple carb adjustment of idle mixture. Sometimes those screws wiggle out of adjustment. Good luck.
