Tractor Talk Discussion Forum
Farmall M
Mr V
06-22-2007 06:34:38
Hey, thanks for your replies. I really appreciate them. Ithink that while I am on here I will ask some other questions also. Has anybody on here put power steering on an old M? If so is there somewhere (a website maybe?) that I can go to find out how it is done? Also, my valve cover gasket is leaking. Should I get another one and where? Or should I just make one out of hi-temp silicone? Thanks again!
roger roland
06-22-2007 21:47:08
 Re: Farmall M in reply to Mr V, 06-22-2007 06:34:38
i have everything u need a behlen power steering set up u get pump, powersteering , short shaft off it to middle joints (steering shaft) & hoses it was hooked into belly pump so no resivor easy set up 875.00 plus shipping im gonna guess if i shipped parts seperate would be cheaper as can get one in a flat rate box 75. to ship all last set i sold on ebay fetched me 1000. so thats how spendy they are getting located in nebraska or ill sell ya the whole M for 1000 non running needs rings i think was blowing oil but i havent had it running myself thats just what i was told
georgeky
06-22-2007 07:54:38
Yes, lots of Ms have had power steering put on them. You can put a couple different set ups on it, but the one you will want is Char-Lynn. It requires a hydraulic motor installed in the steering shaft just under the hood. If you don't have live hydraulics it will also need the pump mounted at the front of engine and a priority flow valve and coupler. OEM has most of these parts. They sell on ebay often, but are high either way. OEM's number is 1-800-283-2122. You might also call Brad Marshall and he can likely get you a good used outfit and has all mounting info. at 1-888-824-0544.
HENRY E NC
06-22-2007 20:17:26
 Re: Farmall M in reply to georgeky, 06-22-2007 07:54:38
I have been getting some good used stuff from Steel Wheel Ranch. He has almost anything used from Farmalls. Prices are not bad either. I'll bet he has some used Char Lynns
