Tractor Talk Discussion Forum
Proper Air Pressure
nc140man
05-19-2005 11:47:22
Hey Guys, Just had My tires put on new rims on My 140, 11.2x24's rear and 5x15 front. What is the proper air pressure in these things!?! Kinda bothered Me the tire place didn't know but He did a good job on mounting them (didn't put a scratch on the new rims) but didn't know the proper air pressure. He put 35 psi in them and it seems to be a little high. Is there any resourse guide or something that I could look up to find out? I appreciate the help! Thanks! Scott
nc140man
05-19-2005 13:50:34
 Re: Proper Air Pressure in reply to nc140man, 05-19-2005 11:47:22
Thanks Guys, thought they should be at lower pressure, still in the process of restoring her so for now probally back them down between 15-20 psi. Maybe by end of summer I'll be done and I'll post a picture. Learned a lot from these forums and put the info to good use, keep up the good work! 'Later, Scott
RustyFarmall
05-19-2005 12:30:49
The front tires should have the recommended maximum pressure right on the tire. 11 to 12 should be enough for the rears. I think about 20 would be max for the rears, and only if you are using mounted equipment.
Steve (Magnolia, TX)
05-19-2005 11:50:00
I would think that your OM would have it? the 11.2x28's on my 8N have 12PSI with 27PSI in the 4.00x19's on the front...
HTH
Steve
