Tractor Talk Discussion Forum
cant pull farmall b engine out
george mall
05-17-2005 18:08:03
having problem pulling engine out of a rusted farmall b.comes out about one inch but cant pull any more. need some help.
Bernie in MA
05-17-2005 18:36:25
 Re: cant pull farmall b engine out in reply to george mall, 05-17-2005 18:08:03
I had the same trouble pulling the engine on my JD 420. The half-round cover over the flywheel was still attached. Bent it up pretty good.
Dixieland
05-17-2005 18:27:26
Hi George, This is not the first time I have heard of this. The only thing I can imagine is the spline is rusted stuck in the pressure plate. Put some lubricant on it(liberally), WD-40 or PB Blaster which ever you have to break the rust and pry it with a crowbar. Be carefull, it may pop loose when you least expect. Good luck...Dixieland
