Tractor Talk Discussion Forum
Ford 5610 Fuel Injection Pump Timing
Brad Root
05-16-2005 23:39:19
We just replaced the short block on a Ford 5610 (4cyl, 256) engine. It runs idles great and runs well, but as you rev up the engine is becomes obvious that the timing is slightly off. Short of purchasing a service manual for $200, we have not been able to find the procedure for timing this fuel injection pump (rotary style, outside throttle). Any suggestions?
Thanks!
-Brad
Jerry/MT
05-17-2005 10:01:06
 Re: Ford 5610 Fuel Injection Pump Timing in reply to Brad Root, 05-16-2005 23:39:19
Yeah, buy the factory manual or get the cheaper IT manual if it has the instructions in it. It takes some special tools to time the pump. You might consider taking it in to a place that works on injection pumps and maybe they can do it for you for less than the manuals and the special tools.
There is a note in my manaual that says that to account for backlash in the timing gears, you should rotate "the pump 1/2 division clockwise(as viewed from the rear of the pump) relative to the zero degree mark on the rear of the engine front plate." You might try this and see if it improves the situation.
