Tractor Talk Discussion Forum
check row planter ?
mgb
05-16-2005 09:54:21
If corn planted with a check-row planter is to be plowed once up and down and then across or at a right angle; wasn't that second plowing pretty rough? I mean anyone who has ever driven a tractor across rows knows that even at the slow speeds and with low rows it can be pretty bumpy. I guess it just proves once again that the earlier generations WERE tougher.
RAW in IA
05-16-2005 15:48:50
 Re: check row planter ? in reply to mgb, 05-16-2005 09:54:21
I grew up cultivating wire check corn. Wasn't too much of a problem 2nd time through because you didn't go that fast crossing the field. Usually had a few crooks in the rows. Also, we had som flex tine units on te rear of the cultivators (farmall C and F-20) that did a good job of taking out the ridges from the shovels. By the was our core fields at home were 120 rods long and about 30 rods wide. A lot of turning, especially with the F-20 and hand lift.
Delbert From Lincoln
05-16-2005 11:53:01
Delbert from Lincoln
05-16-2005 13:49:56
 Re: check row planter ? in reply to Delbert From Lincoln, 05-16-2005 11:53:01
Its been about 60 years since I cultivated checked corn, but its an experience I'll never forget. F-12 Farmall, on steel, manual lift lever on each side for 1/2 the cultivator. Also the cultivator was hooked to the front steering bolster so it shifted to left or right slightly when you steered the tractor and made the steering wheel turn that much harder. When I came to the end of the row, I had to push in the clutch, take tractor out of gear, let clutch off, stand up to get enough strength to lift the cultivator out of the ground., one side at a time. Then set down, push in the clutch, put tractor in gear, let out clutch, turn around, repeat above to get cultivator back in the ground. Then there were the cross washes in the field, usually deeper then the previous cultivator marks, and usually at an angle so that one front wheeel droped in before the other one and tried to break your shoulder, then the other front wheel droped in and twisted you back the other direction. Did I remember to mention that steering wheel was a solid cast iron one, not a bit of rubber grip to it. I'm old and crippled now and in a wheel chair most of the time, but I don't miss the good old days at all. Oh yes, throttled down going thru that last cross ways ditch, didn't get the throttle open again quick enough, engine stalled and had to get off and crank it.
LAW/MN
05-16-2005 17:25:57
 Re: check row planter ? in reply to Delbert from Lincoln, 05-16-2005 13:49:56
You have really stirred some memories. My start in
cultivating was with an H with no hydraulics did have rubber tires in 1945. Several years later after returning from 4 years in the service, the first thing I bought was a used hydraulic pump and used cultivator. Then I left the farm again and my father used that same tractor until he retired in 1978. We discontinued checking corn in the mid 50's, so I had only several years of cultivating checked corn.Thank you for sharing your experience, I really enjoyed it.
Merle Hoppenworth
05-16-2005 10:18:12
Farmall B, armstrong steering, armstrong cultivator lift, cultivating 5 times will equal 2 total shoulder replacements at age 65.
JMS/MN
05-16-2005 10:06:56
It was rough, but even worse was if the farmer didn't keep the check wire tight, it made for very crooked cross rows- then it was harder to steer quickly enough to follow rows without cultivating out the corn. The armstrong power steering unit was most common on tractors back then, and that's another reason why our arms were stronger than those of most city kids.
