Tractor Talk Discussion Forum
I H 340 utility tractor
gary strine
05-15-2005 12:06:50
our boat club has a 340 utility I H tractor and we can't figure out how to add Hydraulic oil!!!
Catskill Pete
05-16-2005 07:01:43
 Re: I H 340 utility tractor in reply to gary strine, 05-15-2005 12:06:50
The 340 combines the hydraulic & transmission oil. To add oil there is a plug with a 3/4 square head on top of the transmission case, slightly behind and to the left of the gearshift. Because of the gear/hyd combo be sure you use the correct oil, IH HYTRAN or its equivilant. Also to check the oil level as you fill it there is a small 1/4 plug on the left side of the transmission case, hidden annoyingly behind and slightly below the foot plate. Remove the plug, [looks like a 7/16 cap screw] and fill till oil comes out the small hole.
