Tractor Talk Discussion Forum
Front loader on a TEA 20
Dean Campion
05-14-2005 13:02:00
i have recently bought a front loader for my 1948 pet/tvo TEA20 and am unsure of how it fits to my tractor. I would be extremely grateful if anyone could send me some photos of the fitting of the belly bracket and the brackets which go to the rear of the tractor. If anyone can help me i will be very happy. Thanks Dean Campion
MSM
05-15-2005 04:23:38
 Re: Front loader on a TEA 20 in reply to Dean Campion, 05-14-2005 13:02:00
If it is a Sauder loader,the belly bracket bolts to the 4 bolt holes on the bottom of the transmission case.If you have a swinging drawbar,the Sauder bracket bolts in its place. There should also be 2 brackets that bolt to the front axle that the loader frame rests on and keep it moving from side to side.The rear bracket hooks to the 3pt arms and attaches to the tractor top link bosses to hold the 3pt in place. The 3 pt must be locked in place so the hydraulic oil that feeds the hitch is diverted(remove pipe plug at right side of trans cover and attach hose) to the loader cylinders unless your tractor has a 2 spool valve mounted on top of the trans case in which case it is plumbed to it.
