Tractor Talk Discussion Forum
steering u-joint
Jerry Wallen
05-14-2005 09:25:58
I am looking for a steering u-joint for replacment on a Sears Economy it is 7/8" bore both ends and uses set set screws to lock it on the shafts. does anyone know what size a wd or wc Allis uses? or possibly another brand that might work in this application?
Bob
05-14-2005 10:31:36
 Re: steering u-joint in reply to Jerry Wallen, 05-14-2005 09:25:58
Go to a industrial bearing and driveline shop or a heavy truck shop. There will be no problem finding joints that size, as the are used in PTO systems on trucks.
A REAL auto parts store that has a "U" joint catalog, Precision, for example, can get samll joints for you. You can buy the yokes and crosses individualy, and mix and match what you need.
If you have trouble coming up with some part numbers, post back, and I'll get some numbers for you, when I get back to the shop.
