Tractor Talk Discussion Forum
TOUGH TIME
jim farmall b
05-12-2005 18:01:37
I AM HAVING A TOUGH TIME PULLING THE MOTOR OUT OF THIS B IS THERE THAT HOLDS ON TO THE SPLINE SHAFT. IT COMES OUT ABOUT ONE HALF INCH BUT THAT IS ALL. ANY HELP WOULD BE GREAT.
Dixieland
05-12-2005 18:46:51
 Re: TOUGH TIME in reply to jim farmall b, 05-12-2005 18:01:37
If you can get a crowbar between the torque tube and engine block it will pry apart. Just be sure the torque tube is secure and engine is secure to perferably an engine stand. There are two line up pins about 1 inch long, one on each side.
JIM FARMALL B
05-13-2005 05:57:29
 Re: TOUGH TIME in reply to Dixieland, 05-12-2005 18:46:51
TRIED CROW BARS TO PRY OUT. THE LINE UP PINS ARE OUT ABOUT I INCH IT JUST WONT LET GO OF THE SPLINE.
Farmered
05-13-2005 23:29:12
 Re: TOUGH TIME in reply to JIM FARMALL B, 05-13-2005 05:57:29
Better figure on replacing the transmission pilot shaft if the splines are worn that much. Just keep wiggling and turning until it comes apart. Better replace that motor with an engine too. I hate to think of you running that tractor with an extension cord! Ed
