Tractor Talk Discussion Forum
JD L130 Hydrostatic Drive Belt
Mike7468
05-12-2005 06:37:13
Hydrostatic Drive Belt jumped the pulley at the rear end, belts pretty frayed and I need to replace it. Looks like I"ll have to remove the mower deck and the right rear tire. It looks like a pain in the rear to get to. Anyone ever dealt with this if so, I"d like to hear some ideas.
nater
05-12-2005 18:53:45
 Re: JD L130 Hydrostatic Drive Belt in reply to Mike7468, 05-12-2005 06:37:13
Remove the mower deck and lift the front of the mower with a hoist or tip the mower on it"s side you will have to remove the pto clutch off the bottom of the motor and probably remove the tie rod for the steering usually you can rplace without removing wheels
Mike7468
05-13-2005 04:59:55
 Re: JD L130 Hydrostatic Drive Belt in reply to nater, 05-12-2005 18:53:45
Well it wasn't as bad as I thought, removed the mower deck, had to disconect the electrical work on pto, and pull the steering shaft out, wasn't as bad as I thought it would be.
