Tractor Talk Discussion Forum
2010 shifter problem
Kip
05-11-2005 18:26:31
I posted this on the deere board and haven't got any response. My 2010 diesel just lost all even numbered gears. The odd and reverse works fine. Theres no grinding noises and pulling the cover, I don't see anything broke. It had been working fine. Any ideas? Thanks
Rob in Oregon
05-12-2005 16:21:50
 Re: 2010 shifter problem in reply to Kip, 05-11-2005 18:26:31
I'm sorry that I can't help with your problem, but you reminded me of something.
The first tractor I ever drove was a 2010 with the same symptom as yours. Being new to machinery then, I didn't know that it was broken or how to shift or anything else for that matter. The owner of the machine put me up there to help pull out his 2940 that was stuck. He showed me low gear, the throttle, clutch, and brakes. I eased it up until the chain got tight then I poured it on. After the 2940 was free, he unhooked the chain and took off for the barn to see some visitors. About twenty minutes (and 200 yards)later I roll in, still in granny gear because I didn't understand the shift pattern. I hope they all thought I was just being careful! Thanks for the memories.
twopop
05-11-2005 20:06:24
the even number gears are all high range.the high range collar and the low/reverse collar are keyed to the front input shaft.i believe the key for the high range collar is sheared.with the cover off and in low range,you should not be able to rotate the high range collar.if you can,the key is sheared.
