Tractor Talk Discussion Forum
Checking hyh. fluid w/ loader
mikeinWA
05-09-2005 10:24:12
Just curious. I was taught to check hydraulic fluid level on loader tractors with boom and bucket cylinders fully extended to take up max volume of fluid. What do you guys do?
caseyc
05-09-2005 11:13:14
 Re: Checking hyh. fluid w/ loader in reply to mikeinWA, 05-09-2005 10:24:12
as old said it would greatly depend on the tractor. i check mine when the loader is down and have never had a problem. i believe that a tractor is designed to hold enough capacity for the equipment attached to operate, not to "open all the equipment up" and then fill the tractor full. when you do that then take the equipment off your tractor is over full. just my 2 cents.
casey in SD
JCH
05-09-2005 10:51:19
Most loaders have double acting cylinders. There's always the same amount of fluid in them regardless of the ram position. If this is true with yours it shouldn't make any difference.
Dr.EVIL
05-09-2005 11:15:31
 Re: Checking hyh. fluid w/ loader in reply to JCH, 05-09-2005 10:51:19
That's not entirely true. The difference in volume between an extended 2-way cyl. & retracted cyl. is the volume of the piston rod/rods. And on loader cyliners that can be considerable. Crude as it sounds I do the same as mentioned below.... When the loader won't raise all the way I add a quart or two more fluid. If the res. gets over filled I have heard of the old IHC Belly pumps on H's & M's exploding from being over filled. My Super H is a Stage II and I want to keep the pump from sucking air as the level in the res. drops when the loader is raised all the way up. The two 2-1/2" x 30" cyl. with 1-1/2" rods use up most of the 6 quart system.
old
05-09-2005 10:47:16
Really depends on the tractor and the system, if I did that on one I have it would dump out a gallion or 2 of fluid when I let the boom down
Farmall Don
05-09-2005 14:34:14
 Re: Checking hyh. fluid w/ loader in reply to old, 05-09-2005 10:47:16
Thats what happened to me and made a mess in the shop.
old
05-09-2005 18:58:35
 Re: Checking hyh. fluid w/ loader in reply to Farmall Don, 05-09-2005 14:34:14
Yep you have to know the system to know how to check things.
Allan in NE
05-09-2005 10:27:23
Hi Mike,
Don't even think about it 'til the derned loader won't go up. At that point, I just dump in a gallon of 'erl'. :>)
Allan
Yeahbut..................
05-09-2005 10:44:54
 Re: Checking hyh. fluid w/ loader in reply to Allan in NE, 05-09-2005 10:27:23
You got mega-money.....
Allan in NE
05-09-2005 11:28:15
 Re: Checking hyh. fluid w/ loader in reply to Yeahbut.................., 05-09-2005 10:44:54
You are hanin' out with the wrong crowd. That be a derned lie! I 'taint got nothin' cept the "want". :>(
Allan
Farmall Don
05-09-2005 14:33:15
 Re: Checking hyh. fluid w/ loader in reply to Allan in NE, 05-09-2005 11:28:15
All them horse people have money.
Sloroll
05-09-2005 14:35:50
 Whoop! Correction There. in reply to Farmall Don, 05-09-2005 14:33:15
Slight correction: All them horse people "Used to" have money.
Allan in NE
05-09-2005 14:40:56
 Re: Whoop! Correction There. in reply to Sloroll, 05-09-2005 14:35:50
Yep,
When we get this little dirt deal done, we're talking your basic "strapped/poor house" and the children's inheritance is gonna be history.
But, it'll take 'em a week to get the smile offn' my face when they lay me down. :>)
Allan
caseyc
05-09-2005 11:36:14
allen, when are ya gonna learn you can't fool us!!!! them pretty red tractors of yours don't lie!!!!
casey
Allan in NE
05-09-2005 14:36:43
 Re: Checking hyh. fluid w/ loader in reply to caseyc, 05-09-2005 11:36:14
See,
That is the problem in itself. Spent a wad on the tractors.
Now, I gots no more marbles to play with; just the tractors. Can ya loan me a tankful of diesel so's I can at least hear 'em run? :>(
Allan
third party image
caseyc
05-09-2005 14:52:42
 Re: Checking hyh. fluid w/ loader in reply to Allan in NE, 05-09-2005 14:36:43
if you come pick it up in person i sure would give you a tank full of fuel for the tractor (you gotta bring the tractor too!)
